TwinTurbo.NET: Nissan 300ZX forum - I have the fuel code fault as well when I pull the
Subject I have the fuel code fault as well when I pull the
Posted by SammybTT(TN) on June 19, 2014 at 6:11 PM
  This message has been viewed 285 times.
In Reply To Fuel temp sensor posted by elvee18 on June 18, 2014 at 10:58 PM
Message codes. It will not turn on the CEL but it will show up. My problem appears to be an intermittent sensor that I plan to replace when I return home. It is easy enough to replace so I will try that before necking out the wiring.
